Ddro12 10+ year member
I have a question. when you have a two channel amp can you run a sub off each channel for example. If I ran 2 12w7's off a memphis mojo amp or off orion xtr pro amp would I be getting 1000 watts to each sub or will the amp fry because of the ohm load. I'm asking this because I can get either amp for 450 dollars and I wanted to switch my on 1200.1 xenon amp running of one of the subs. plus I want to run both of them at the same time.
