Connection issues
i don need to be disrespected like that n neither does my cousinhe set up his own system in his car so im sure he knows
so if u don have anything to help me out
then don respond bak here its simple as that
theres other people willing to work with me as im
new at this..sry im not as knowledgeable about all of this as u
im just using this forum so i could save some money
but if people are like this around here then im out
please o please take pics of his setup. PLEASEEEE //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
everything is a bit messy but you power looks like it should be good, as long as your fuse is ok.
take a really good picture of the exact point where you have your ground cable connected.. This is important. And also, what are you using for your remote turn on source. For trouble shooting sake, just jump those terminals together. If it turns on by doing that, it is your remote turn on wire. If not,, it is most likely your ground. if no luck, Try doing what i said earlier. Also,, check the fuses on your amp itself. Do you have a digital multi meter to test your current?
In the video I'm still only seeing 2 wires to the amp where there should be 3. There is no wire connected to the +12v terminal on the amp (it should go to the + side of the battery)
Ohk so ive been doing some work on it myself
and i hooked everything bak up n i grounded it to a different spot on my car
the amp light turned on when i did this but the subs werent bumpin
so now wat mite be the problem??
CTMiller32
CTMiller32
CT
gury
