Connection issues
oh no when it was connected it didnt work
its disconnected rite now thats why
my cousin was putting it in
and then after when it didnt work
he jus took the fuse piece out so it wont be connected to the battery anymore
come on guys im not that dumb loll
Is there a way i can take some sort of video n put it on here??
Yes photo bucket lets you upload videos but that isn't going to help.
What deck do you have?
Where did you buy the amp?
Did the system ever work?
Did you check all the fuse connections?
Did you sand off the paint by your ground connection?
Where did you ground it?
How long is your ground cable?
Did you buy that whole package at the flea market?
What kind of ohm load is the amp seeing?
Answer those and that would be a better start in troubleshooting what you may have done wrong
yea because we didnt want it to get damaged and we didnt want to keep it hooked up to the battery either when the system is not even working
thats why in the pics its not connected not because i didnt connect it
come on now lol
i don know what a deck is
i bought the amp n sub at circuit city, they came together in a bundle pack
no it never worked when it was fully connected
yea my cuzin checked all the fuses, he doesnt kno wat went wrong
i did not sand anything off, nor do i know how to do
idk wat its called that we grounded it too, but theres a picture of it
theres a pic of ground to the amp also
Use a multimeter and check for +12v at the amp's end of the +12v wire and for +12v on the remote wire at the amp's end. Disconnect the wires when checking so you're sure it's not bleed through voltage from one to the other. Also make sure your GND has good continuity to the chassis, paint scrapped away, etc.
Well here is the problem: Neither you or your cousin knows whats what in car audio so having him check stuff is as useful as Santa giving financial advice. What I would do if I were you is stick around this site read all the stickies in each section and hopefully you will learn whats what in car audio thus giving you the ability to know what the hell you are talking about which would help other members find out whats wrong with your system.
i don need to be disrespected like that n neither does my cousin
he set up his own system in his car so im sure he knows
so if u don have anything to help me out
then don respond bak here its simple as that
theres other people willing to work with me as im
new at this..sry im not as knowledgeable about all of this as u
im just using this forum so i could save some money
but if people are like this around here then im out
i don need to be disrespected like that n neither does my cousinhe set up his own system in his car so im sure he knows
First of all no disrespect intended until now
I was being blunt because I have tried very hard to help you and all you can say is I don't know... other members wont even do that so feel lucky. If your cousin puts a fuse over 10 feet from the battery then he is an idiot because that defeats the purpose of the fuse. You are a fuccking idiot and your cousin is too //content.invisioncic.com/y282845/emoticons/bigwave.gif.16324171cad2db62cf4f16568b038478.gif
CTMiller32
CTMiller32
CT
gury
