? concerning electrical upgrades to be done and will this suffice?
theothermike
I HAVE NO LIFE, CA = LIFE
Right now my electrical consists of 1/0 gauge big three. 2 batteries. big capacity under hood and med - small battery in back. 1/0 gauge power run to battery. then another 1/0 gauge run to distro which splits in 4 gauge kollosus wire to power terminals on amp. 4 gauge from amp grounds to distro to a 1/0 gauge wire.
I getting about 12.5 volts at amp idle with music on med - high.
im running sundown 1000D proto - 90 amps rated
and sundown sax 100.4 90 amps rated
however ill be either getting another 1000D and strapping or selling 1000D and buying a 1500D and running at 1 oh.
Ill also be buying a 100.2 and going active....
Ill have to add another 1/0 gauge run to another distro probably
Here what i thinking of buying
either a 180 amp iraggi alternator dominator series with 80 amps at idle
or 200 amp iraggi alternator dominator series with 70 amps at idle
And possibly upgrading batts to a 1400 - 1800 kinetik under hood and a 2400 in back
or going 34 yellow top optima and group 31 yellow top in back
Out of all the options which would u pair up with which and u think itll be sufficient to run what i going to run?
Mike
can don (iraggi) add one to mine or is it like a universal thing? how much more will a smaller pulley be?
tell him what you are wanting to do, that way he can get you what you need. he has pulleys and such even mods the stator to give more power on low end. batteries are good to match up with. some people will say no some will say always. key point though is an alt isnt always putting out peak power (rpm load dependant) so the batteries act like a safty cushion while the engine is on. second battery will lower the voltage drop from front to back. also big benifit if you ever do engine off listening
audio life not sure if u were guy who helped me out with over at diymobileaudio... but u been big help here...
thanks... we could use a ton more people like you..
Glad im not only person who doesnt say search and actually helps people.. =]
theothermike
theothermike
Tampa
theothermike
michigan born
    May 14, 2026
michigan born
    May 14, 2026
