Components minus tweeters - in the rear
TheEd
I've searched the forum and only references I can find are referring to the front and even then no definite answer.
Here is my situation, a 2010 Hyundai Genesis Coupe with stock head unit, one of the rear speakers have blown. The factory rears are just mids, no tweeters. I have a set of cheap components laying around and here is my dilemma, I definitely have no use for the tweeters in the kit, do I use the crossovers and not wire up the tweeters or do I leave out the crossovers and wire directly to the mids?
The components in question, the mids are 2-ohm and the factory speakers it is replacing are 4-ohm.
Two issues I see. First they are 2 ohm and you need to find out if stock head unit will run a 2 ohm set. More than likely not. Second if you just use the passive crossover, what is the x over point? Lets say the passive is 3500hz, that would mean a huge part of your vocals would also get cut out because the tweeter isn't there playing them. They may or may not work as rear fill. I think you could find a cheap pair of full range drivers that are 4 ohm. I thought Parts Express has a cheap pair of full ranges for like 15 bucks or so.
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
In the $600 range I like my stereo integrity speakers so far Tm65 midbass $399 m25 tweeters $199
What are some of the louder, while still sounding good, 6.5" sets out there? Been looking at some of these higher powered Sky High Car Audio sets...
Hell... Run It!! If it sounds good to you. Then that is what matters the most.. Your OWN EARS.
TheEd
TheEd
United States
Jroo
    May 24, 2024
    May 23, 2024
