Component speaker question
Could be a wiring issue. Or connection issue. I would go back and recheck those things. Did you play with any settings on the HU before this occured?
no I didn’t mess with anything at all yet correct me if this is untrue if it is a wiring issue the only logical issue has to be between the crossover and woofer I say this because the tweeter seem loud and crisp which means the input is fine and output to tweeter is fine am I correct in this thinking?
Try switching channels on the amp. Put the weak sounding speaker on a different channel and see what happens.
This.
Is your best bet...will rule out of the ch on your amp went bad or isn't working properly.
Or try switching x-overs...that will rule out a defective x-over too, if it is.
Mascola222
Mascola222
Nova Scotia,Canada
Boomin_tahoe
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
