Complete System Install Cost?
Thanks everyone. I think I've decided on the following:
Image Dynamics CTX65CS
(2)Image Dynamics ID12D4 V.3
If I got an MB Quart DSC4125 and bridged channels 3 and 4, how much power would each sub be getting? Thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
nice amp choice
The Crescendo 1000C4 is a MUCH better amplifier than the MB Quart DSC4125. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif Trust me, man. Spend the extra cash on the better amplifier.
Neither amp is powerful enough (the MB or the Crescendo) to sufficiently power a pair of ID Q 12"s. You'd want 1,000 watts rms for a pair of those subs.
Ok so you are about prepared to pay $600 to get it installed.. you spend $100-$200 on a round trips worth of gas.. maybe a little more.. give me $100 for time and I will do it and right... I will also show you what I am doing so you can do it next time... Hell Have an extra room you can stay in aswell.. so for 200-300 you can get it done and visit florida before the oil hits..
and I am SERIOUS.. If you are down.. let me know..I have a whole HOUSE that no one is living in right now..
Alright, so what amp would I be looking at for the set of comp's and the two 12's?
If you want two subs and a pair of components you're going to have to make a sacrifice. In order to use the Crescendo amp, you'll have to opt for a pair of subs that require little power (200 - 250 watts rms each). The other alternative is to buy a pair of amplifiers ( a monoblock as well as a 2 or 4 channel). You aren't working with a very big budget, so the overall quality of the amplifiers you can afford will take a dip if you have to buy two of them....unless you purchase used equipment.
Do you think you won't be satisfied with a single subwoofer? In all honesty, a single ID Q will perform well if you have an enclosure built to ID's specifications.
I want to use these enclosures:
http://www.bassforms.com/PhotoGallery.asp?ProductCode=BF212GTI&PhotoNumber=12
(I can get 2 enclosures on ebay for $250)
In my old car I had a Rockford PL2-212 loaded box powered by a Rockford P500 (all from Best Buy, lol) and I was happy with it.
What's a good monoblock & 2-channel amp combo if I wanted to use the two ID12's? I'd be willing to stretch my budget if it was worth it.
If I just wanted to use the 1000C4, what subs would work best?
I love my image dynamics comps (ctx65cs) and I had to RMA it once like a year after I purchased it, no issues to do it. Blew it again this weekend so Im going to see what they say tomorrow but I think they make a great speaker and wouldnt hesitate to purchase them again.
You could go with the crescendo 6.5s too, Ive heard good about them and thatd save you $80-100.
Id go ID Ctx65Cs
Crescendo 1000c4
and ID Q for sub (just 1) 12 and youd want Dual Voice Coil 2 Ohm so you could wire to 4 ohms (the crescendo would give off 500w @ 4 ohms)
If you buy a pair of amps:
Sundown SAZ-1000D & SAX-125.2 ($515.00)
Audioque AQ1200D & AQ4X90 ($479.00)
If you want a pair of subs for the Crescendo:
10" SSA Dcon 4 ohm dvc ($230 for the pair)
10" Arc Audio ARC10D4 4 ohm dvc ($360 for the pair)
12" Image Dynamics CTX128 8 ohm svc ($218 for the pair)
10" Boston Acoustics G21044 4 ohm dvc ($220 for the pair)
I could go on and on, man...
Sure they are but does this change the fact that a groud wire is a ground wire or a power wire is a power wire, the answer is no. An alternator does the same thing in a mercedes as it does is a '67 roadrunner. As I stated the concepts are the same applying them to any car is the same how you might have to run the wire in a mercedes compared to a suburban does not change anything.
My guess is you haven't done many installs. There are many cars that need special attention and/or equipment. My car's remote-entry, security, personal memory settings and a bunch of other electrical stuff stopped working after I removed the factory headunit. If I turn the car on then off right away the whole dash flashes and a bunch of relays start clicking. Turns out the factory deck HAS to stay connected with the car(it has a databus running to it) and I had to do some custom wiring to relocate the factory deck to the trunk. METRA's little interface doesn't work and Pac-Audio don't even make one for my car.
Yeah go try and install something in a new Mercedes, I dare you.
Alight, here is what I'm gonna order tomorrow morning:
Eclipse CD5100
Image Dynamics IDQ12V3.D2
Crescendo 1000C4
Enclosure:
Bassforms 12" sealed box
Speaker Adapters:
8" adapters
I know there is a bunch of extra shit I'll need to buy. Here's what I've thought of so far:
- C2R-VW radio adapter
- double-DIN mounting kit
- antenna adapter
- Dynamat
- 8 or 4 gauge (?) amp wiring kit
Will I need to buy any extra speaker cable or RCA cables? Is it worth it to buy foam speaker baffles?
LostArk
LostArk
WNY
audioholic
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
