cotjones
- Thread Starter
- #31
FINNALY someone with brains! thank you sir!Your system could sound perfectly clean there is no real way to tell unless we all heard it. It is just when you mix different size subs or the same size different brand there is a good chance that there will be cancellation or in other words the "timing" of all of the subs could be off. The more subs you have whether or not they are exactly the same sub the more of a chance of cancellation and or blurring of the sounds. Chances are the larger sub might be ahead of or behind the others and on most songs you would probably never know. Instead of taking the chance of cancellation you might as well just add anonther ten to the mix and get rid of the 13.5 that way you do not run the risk. The specs on different size subs are different even if they are the same model which means that the subs are "reacting" different to the same signal. Tens can play just as low as 15's so I would not worry about adding a larger sub.
