comment on my setup
dude if you know so much why are you posting on here?
i could really care less if you dont want to take our opinions dont make stupid threads
mixing subs of different sizes is ignorant.
dude i haven't heard a single opinion yet only comments like you are a retard and so far it looks like no matter what i post i will get a comment like that on this site
It looks like more of a bling factor. . . I dont think you know what SQ is if you think thats the best you've heard. . . . I bet your front stage blows. . . .
your right! i have mtx components 6 1/2 in the back and 5 1/4 in the front and 2 extra pairs of mtx tweeters
Dude...we have all heard setups with different size subs in the same box, in a different box. Cancelation sounds like ***, its un mistakeable. I dont care if its a pair of Sony Xplods or Focal Utopias...its gonna sound bad. If it sounds good to you, fine...but don't expect sympathy from those of us who know better.
yeah...go to http://www.carstereo.com
they will love you there, pat you on the back, and you can even win some H2H battles, and get an ego boost. then when you make your way over to the local MECA/IASCA/USACi/dbDrag show, and you compete, and get your *** handed to you, your online buddies will still be there to pat you on the ***.
there is no cancellation! fer cryin out loud the 13 is set to 35 hertz and the 10's are set to 60...
Your system could sound perfectly clean there is no real way to tell unless we all heard it. It is just when you mix different size subs or the same size different brand there is a good chance that there will be cancellation or in other words the "timing" of all of the subs could be off. The more subs you have whether or not they are exactly the same sub the more of a chance of cancellation and or blurring of the sounds. Chances are the larger sub might be ahead of or behind the others and on most songs you would probably never know. Instead of taking the chance of cancellation you might as well just add anonther ten to the mix and get rid of the 13.5 that way you do not run the risk. The specs on different size subs are different even if they are the same model which means that the subs are "reacting" different to the same signal. Tens can play just as low as 15's so I would not worry about adding a larger sub.
cotjones
cotjones
Wilmington, NC
sku
