Chevy Avalanche encloure? or not.
  • 4
Seehafer27
hello, i have a 2004 chevy avalanche and i want to put a system in it but i still am going to use the bed. so my question is would it be good to put an enclosure in and just take it out when i wanna use the bed (won't be that often) or just do a normal box, but if i do a normal box could you even here the base? ( 2 Audio que HDC312 on 2 audio que d1200)
Wrong section
Report the post do not post dump in it...
That is up to you, but a removable enclosure would be fairly easy enough and would do exactly what you need.
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
541
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
I would add two more of the same subs and look at selling the 2k to go towards the funds of a decent 5-8k mono amplifier and new enclosure
Seehafer27
Seehafer27
Corona, SD
pro-rabbit
slater
    May 2, 2024
slater
    May 2, 2024
