check my design
king ranch
Banned
so i am trying to make my own box for 2 12's l7's ported
i used re audio box calculator
heres what i came up with
box width 35
box height 17
bottom depth 21
top depth 21
wood is .75
port width 4inches
port length 2 is zero
port lenght 1 is 16.25" but it says the total port length is 23" why does it say that
leaves around 5cuft net and at a 33hz tune will this work
also is the ox volume net and when adding up the net do you add the port displacement in with net or does it get used as taking up space
yes to what it will work
also why does it say the total port length is 23" when it shows it being only 16.25
also with port displacement it should be right around 5cuft net correct
do you add the port displacment for net or do you subtract the port displacement from the voulme of the box
wats the formula for figuring out how much port displacement is
The RE box calc takes the port displacement out of the box volume, all you need to subtract is the sub displacement.
king ranch
Banned
king ranch
fl
king ranch
