Check my box idea
krout206
This is the box design I have in mind. Its going to be a separate box mounted underneath a floor structure in the back of my civic hatchback. From what I've figured it should be 1.28ft^3 ported with PVC tuned to 35Hz. I plan to run a single 10" Kicker Comp VR. If some of you experts can check my dimensions and give me some feedback it would be greatly appreciated.
u've got approximetely 1.18ft^3 after sub and port displacment.....assuming 3/4" mdf, schedule 40 PVC and a sub displacment of .05ft^3..if the sub is larger, then u've got even less volume...
but for most tens, that should be plenty..the cvr should do just fine in there...however, with the smaller volume (if u used 1.28ft^3 to figure tuning), ur tuning will be a bit higher...probably in the 36hz range..not enough to matter...
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
Do you think that setup will give me a good balance of SQ and SPL? Would it tend to lean one way, if so which? I'm looking for the best balance I can achieve but I guess I'm leaning more towards SQ. Thanks in advance.
it's hard to say..i don't know what u consider sounding good..
IMHO, it will give u a nice sql blend...and being a compvr..will probably lean more to the spl side of things...but sq is subjective, u might think,after building it, that it is more sq oriented.
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
krout206
krout206
Arlington, OH
krout206
