I'm not sure why u mention that because that one reason the loudspeak is being designed to be highly versital to beable to be used in a wide variance of enclosures..When you design a system you use the loudspeaker that will use the avabile air space/tuned to supply the proper frequency response..
Among that it has extreme excursion capabilities if needed no other driver can offer that..
Cms will be linear through the excursion and it could literately be varied to compensate power compression among the other losses to maximize input..
First bold part: Because they are not designed for a wide variety of enclosures. They are designed with parameters based on reproduction without the use of the enclosure. The enclosure give it the ability to perform with more efficiency as far as coupling is concerned. Its common to believe that the loudspeaker was designed to accompany the environment instead of the environment being designed to accompany the loudspeaker. This is why it was mentioned. The confusion between the two are huge in figuring for responses.
Second bold part: It must be mentioned that you do not have to explain to me the purposes of loudspeakers. I am highly knowledgable in the field. Now, as far as tuning, this has less to do with the response than you might want to believe. Some enclosures do not incorperate a tuning frequency, but more so inherit a low impedance mark for electrical transfer. if you notice, in quite a few response curves, the tuning frequency does not have a major visual identifiable place, and in a proper enlcosure, it should not, unless that enclosure is designed around a resonance, not just a tuning frequency. You are referring to the simple common bass reflex designs as being the only "ported" enclosures out there it seems.
Third: Compression is not a loss. It give the ability to increase output. Now you said to maximize input, do you mean output?
I want you to understand something right now, because you are starting to upset me, and not very many people can do that well. You are very misguided in the concept of audio. Your "ideas" are great to try to accomplish, but you are preaching to the one of the few choir members in this forum. my goal here is to educate and help those who need it, and by doing so, I would like to stay away from arguments that are not going to accomplish anything. I do apologize that you feel everyone is giving you a hard time, but there is a reason for it. You started a thread about a topic that most of us will not want to understand, which I have fallen in that trap before as well, and had to fight my way out, and ended up with a lot of respect from it. But, you are taking this is a very non-productive way. Either make your point, or this thread will likely die off pretty soon, which I hope it does not. I would like to know everyone's professional opinion about his topic if possible.
I want to make this really clear to you, I believe you are doing a good thing. Now, write that down, because so far, it does not seems that you have understood all of the good things I have said about you so far. YOU ARE DOING A GOOD THING. KEEP IT UP, but do not turn this into a debate of acoustics. I am trying to keep my cool with you and be very nice about everything. We all get that you may know what you are talking about to a point and have a great idea in mind. But leave it at that. I have had to correct quite a bit about your acoustical comments so far, and as a member, I would hope you would learn from it and not go against it. I am no better than you are, but when something is said that needs to be corrected, I will correct it with the hope that it will be helpful, not as a way to make you feel inferior, so you do not have to explain yourself and feel like you need to college me in acoustics. I have been there in this audio world more than you will want to believe. College, military, and trial and error, and years of experience. That is one of the field I had in the military, I was a qualified sound propagation technician. Not much more to say than that.
You need to understand that I am here to help. You need to take that very firmly. my purpose here is not personal. Do not begin to make it personal. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
