Change the way you think about speakers with unreal accuracy
Papermaker85
Banned
Question is are you willing to pay for a special breed of subs and amps that only work in conjunction with each other?
I'm talkin no limit to throw at the same time varing dampening to fit any type of box, tune and musical Taste with the turn of a knob like setting your gains!
Best possible transient response by not using feed back but using the original input signal to provide the proper dampening and impedance matching..
Having a woofer that supports tunes down to 15 hz and using the same woofer in a spl install tuned to 65hz with optimal results?
I don't want to Drop 20k when people don't appreciate someone's else hard work and deadication..
It's nit a end all speaker it's just a **** good design that is capable of doing some no other speaker can..
It has cons like cost and space constraints..
It's just going to be very low distortion high power and variable dampening..
I don't want to Drop 20k when people don't appreciate someone's else hard work and deadication..It's nit a end all speaker it's just a **** good design that is capable of doing some no other speaker can..
So are you trying to ask around if this already exists for the most part? Or are you trying to design and patent this your self? I am personally a little confused on the direction you are trying to take this thread..
No it's not done and none can provide what i'm telling you..No servo which has flaws no cone control circuit..
People don't have different perception when they know what there hearing..
Im sorry, but that is incorrect. THere does exist a perceptual hearing response that is averaged based on mid 20 to 30s age group for thousands of people, and give a great way to get as close as SQ flat as possible, but the variables in everyday life for everyone is different in some way and effects our hearing different. Yes, there are generals, and we tend to use those as they are as accurate as we can get right now without doing hearing tests for everyone we design for, but this statement is wrong due to those differences in lifestyle. People can agree on a systems accuracy, yes, but that has no indication of their hearing abilities and response to be matched.
Papermaker85
Banned
Papermaker85
New orleans LA
Papermaker85
