Center Console Box Design
  • 4
DodgeSlammit
Hey guys im new to this forum, but i was just going to see if anyone could help me out with designing a center console box for my 04 ram. i have 2 memphis 10's that will be in it, i want it to be ported, and i want a screen in it too //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Memphis says it needs to be 2.5 cubes @ 35hz and the port is 10.5x2x19.5. I've designed a few boxes but im not sure which one i want to go with. Maybe you guys have done one before and have pictures? I can do fiberglass and bondo if i need to also. I dont need anything too flashy, ill probably end up wrapping it in black leather/vinyyl when its done. Also, im not exactly sure to tune it to 35hz, will it automatically be 35hz if i build it like it says to? Thank you guys for your help
what are the max dims you have to use for the box.
My truck is in the shop right now //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif so i cant get exact measurements. I know the width would be 14 though. Its a quad cab and it would go all the way from the dash to the cupholders on the floor in the back seat. Ill measure some stuff in my friends truck (same truck) tomorow and put it on here
Design suggestions shouldn't begin until this dude picks a designer and gives him some money. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
This dude, for example, does good work and would have no problem accepting the OP's money...
I wouldnt have any problem accepting money for anything either... I was just asking for suggestions not to pay somebody to design something
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
265
Well I ordered an oscope. Should be here today. And this beautiful beast showed up today. I’m gonna have to redo my battery and ground terminals...
36
6K
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
189
Audio Control ESP 3 is the way to go ..if your wanting to do a quality center channel setup ...
974
DodgeSlammit
DodgeSlammit
Houston, Tx
DodgeSlammit
slater
    May 2, 2024
slater
    May 2, 2024
