carpeting slot ports
evo2k3
Senior Bizznitch
1,035
Chicago
when i do my slot ports, i dont want to see the mdf on the innner edges of the port, but if i cary the carpet down the port, does this create considerable friction, hence poor tunning / poorer response at the desired frequency.....if so how do other people "combat" this problem?carpeting slot ports
id just leave it, or paint it maybe to match ur carpet //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
924
The late 80's early 90's car's OEM speakers were of the same quality as today's offerings. The main difference was the rear speakers were enclosed...
10
You're not trying to figure out the mass of air in your 3" port or whatever, you're trying to figure out the mass of air that you would need in an...
Are you going to do actual aeroports with flares on both ends? I’m running a single 4 inch aeroport on my little 750 watt 12. It has flares on...
The black rca out is your mono sub output. That is the one you would use for signal to your sub amp.
evo2k3
Senior Bizznitch
evo2k3
Chicago
dbhittin
    May 24, 2024
    May 23, 2024
