Car sterio needs some tuning?
Haha, I fail for explaining myself? You fail for spending mommy and daddies money on your set-up, must be nice. I also have another question, how can you tell me if I hit 130, 140, or 150? You obviously have no clue what you are talking about. Man, you belong at SMD. You would fit in just right there. How come you can't provide me pictures of your setup? To the OP, look on the box that you bought the subs/amp in, and see if they say Dual 2 ohm or Dual 4 ohm, and look on the amp box and see what the box says the amp does bridged... Such as Bridged 4 ohm stable, or Bridged 2 ohm stable.
I spend mommy and daddies money on my setup? If that were true, then id be running different stuff. And FYI, you fail for following me, and commenting big *** paragraphs trying to defend yourself. No one gives a shit, so get a life.
* 50-200 Watts RMS (800 Watts Peak Power) 12" 8-ohm Subwoofers
Hahahahaha, following you? I clearly was trying to help OP and you came in, and bashed me, saying I don't know what I am talking about. Correct? And you run 4g for a AQ1200? Great job, you definitely don't know what you are doing. You fail for not knowing what you are talking about. Troll? I think so. If no one gives a shit, why do you keep getting mad brah, and responding? I think you do care. Also, aren't you that NathanLewis *** off of Caco?
4 gauge is for AQ2200 you fool, theres nothing wrong with running that, as it means less resistance. I haven't responding back to you other than you telling me to leave the forum. Goodbye MikeyF, little 15 year old boy.
It's a pair of 8 ohm sub. He can't bridge them lower than 4 ohms so whether the amp can handle 2 ohms bridged or not it doesn't matter...
BassX, you are funny as can be. So your telling me your running a AQ2200 with 4g? You just proved yourself right there that you have not a clue of what you are doing. I actually LOLed when I read that. And to think I actually gave you credit for thinking you ran 0g for the AQ2200. And I was just 19 to you, now i'm 15, which is it sweetheart?
Actually, it does. Because if the amp is only 2ohm stable bridged, that could be the reason it cuts off/gets hot. Wrong impedance level... Dhawk, since you have 8 ohm subs, when they are wired correctly, it should create a 4ohm load. Here is a link on how to wire them correctly...
Subwoofer Wiring Diagrams, Two 8 ohm Single Voice Coil (SVC) Speakers
BassX, you are funny as can be. So your telling me your running a AQ2200 with 4g? You just proved yourself right there that you have not a clue of what you are doing. I actually LOLed when I read that. And to think I actually gave you credit for thinking you ran 0g for the AQ2200. And I was just 19 to you, now i'm 15, which is it sweetheart?Actually, it does. Because if the amp is only 2ohm stable bridged, that could be the reason it cuts off/gets hot. Wrong impedance level... Dhawk, since you have 8 ohm subs, when they are wired correctly, it should create a 4ohm load. Here is a link on how to wire them correctly...
Read correctly pal, 4 gauge SPEAKER WIRE, GOING TO MY SPEAKER. 0 gauge IS GOING INTO MY AMP POWER. I thought you were smart? Guess not.
BassX19, please go fall in a hole and stop flaming some one who is actually helpful. If you want to flame some one take it to PMs...
MikeyF my subs are currently *Left side* +- *Right side* -+ meaning on the right I have a red in a black and a black in a red. If I don't the sub does not hit near as hard.
With a pair of 8ohm subs, there's no way he could wire them in a fashion that would hurt the amp. 4ohms or 16ohms are his only options, which the amp is fine playing at either way(albeit with quite less power at 16ohms)
Hahaha, so you can afford it means you buy it? 4g is the BIGGEST overkill I have ever heard of for speaker wire, let alone with a 2200 set-up. Boy you sure don't know your shit. Seems no one likes you either.
Whats overkill about it? The fact that it has less resistance? Why don't you worry about actually getting loud, and getting some better shit before commenting on mine. Mikey, you sure have alot of guts to be an E-Thug.
Dhawk
Dhawk
Tyler Tx
Wattser93
