Whats overkill about it? The fact that it has less resistance? Why don't you worry about actually getting loud, and getting some better shit before commenting on mine. Mikey, you sure have alot of guts to be an E-Thug on the internet. B*tch again why don't you?
fixed it. =)That's a pretty redundant statement. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
//content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.giffixed it. =)
So why didn't you use 2/0 speaker wire? Or 8/0? The truth is, anything over about 10-12ga speaker wire is completely for looks, and the lower resistance will not create any noticeable or even measurable difference in stereo performance. Remember, an amplifier amplifies voltage, and the higher the voltage, the lower line loss you get for a given wire size. This is why the input power cable is so large, but the amplifiers output speaker wire can be relatively small in comparison. Large gauge speaker wire is for people wanting to show off that they dont understand this.Whats overkill about it? The fact that it has less resistance?
its because i had it laying around. Why shell out more money, when i could make use of the 4 gauge? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif//content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gifSo why didn't you use 2/0 speaker wire? Or 8/0? The truth is, anything over about 10-12ga speaker wire is completely for looks, and the lower resistance will not create any noticeable or even measurable difference in stereo performance. Remember, an amplifier amplifies voltage, and the higher the voltage, the lower line loss you get for a given wire size. This is why the input power cable is so large, but the amplifiers output speaker wire can be relatively small in comparison. Large gauge speaker wire is for people wanting to show off that they dont understand this.
If it's 2 ohm stable and he's running a 4 ohm load then there's nothing wrong with that...Actually, it does. Because if the amp is only 2ohm stable bridged, that could be the reason it cuts off/gets hot. Wrong impedance level... Dhawk, since you have 8 ohm subs, when they are wired correctly, it should create a 4ohm load. Here is a link on how to wire them correctly...
Subwoofer Wiring Diagrams, Two 8 ohm Single Voice Coil (SVC) Speakers
Just because it's stable at 2 ohms bridged doesn't mean it can't run 4 ohms bridged, because 4 ohms is less work on an amp then 2 ohms, so you're an idiot.No, I clearly said if it is 2ohm stable BRIDGED, and he had it BRIDGED, with his load being 4ohms, then their is a problem.... How is that wrong...?
