Car stereo wont work unless door open!
chatman56
canada
I have a 99 chevy venture van, and my stereo wont work unless the passenger door is open. This is an odd problem and i was wondering whats wrong! All four speakers dont work unless i open the passenger door, and when i do they fade in and work perfectly,but as soon as i close the door they all stop working. Sometimes they will keep working even after the door is closed, but when i hit a bump they stop again. Can anyone help? Thanks!!
remote lead hooked up to the same fuse as the dome light //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Nah seriously I dont know thats weird //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
On most decks Ive installed, if you short out one speaker they all cut out, so I would suggest the same as above and check the harness going into the door for a pinched or grounded wire.
Thanks so much for being so quick guys. This is the stock stereo so im not sure what has changed from when I first got it.. Like, I know pretty much nothing about wiring anything and I've never unscrewed anything in my car. I've checked all of the fuses and everything seems fine, so if someone could give me detailed steps as to what I have to do that would be unreal. Thanks!
Oh yeah, I forgot to add, when I open the door ALL FOUR speakers work perfectly, and when I close it, ALL FOUR turn off. And it's not just when I turn on the inside lights either, cause I've tried that with the doors closed. I also disable the inside lights for when I open the door, and still it turns back on.
You can go to theyre Website and check it out/do some research on your own, or even give them a call
33
7K
It should be called the accessory wire...it should be connected so that it only see power when the car is on...if its connected to constant power...
817
Unless Android made some big changes to their core program, it should work just fine. Just like using a 4g phone on 5g sevice.
If the original plugs have been cut off, you may want to get some from a wrecked car. You could also search online for a radio pin-out for said model.
chatman56
chatman56
canada
Dinerodays
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
