patrick1202
ok so my 1993 Chrysler concorde 3.3 is idleing at almost 2k how do i turn it down??
throttle body cleaningok so my 1993 Chrysler concorde 3.3 is idleing at almost 2k how do i turn it down??
yes i dook do u know what a throttle body is
so just clean it lol with throttle body cleanerit could be dirty or have a small leak, my moms car does it too and i have to clean hers
if its dirty the valve will tend to stay open enough to get air in to idle ur car higher, cleaning should workyes i do
do you know how to make the idle lower
Not on computer controlled cars. And even if there was there would be no reason other than some problem that needs to be fixed.what about you're throttle cable at the throttle body..... is it to tight, there usually is an idle set screw you can adjust, to lower/ raise the idle...
