Car battery?
You are missing two very important factors before determining proper battery replacement or even addition. What are the amp hours of the battery now, and also you have to figure for the charging systems alternator amperes. I believe for you vehicle its 115amps. Max replacement stock is 125 and the older models are 105. If you give me a bit I can figure for your proper batt replacement based off of amp hours and wattage hours but I would personally add to the charging system with a deep cell. Not replacing the stock batt unless the cca is too low for the upcoming winter.
Right now if your stock battery was capable of 45amp hours, you are looking at anywhere between 1176-1612.8watts you can use for your audio system-including front stage. And an average of 1456watts. So, with say the mentioned 105ah dekas from bettr n reverse, you will get 2217.6 watts to use and that leaves you with with just over 700watts for your front stage if you subtract the 1500 from the sub amp.
diehard platinum.......well worth the $$$
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif My vote would be for the Diehard.
I'm going this route to, with the temps reaching 113+ in summer. I don't want to know whats the temp under the hood. They are backed by Sears warranty.
Sure thing. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif but I'm not sure where the best place to get one would be. There are a few on here that have good deals.
cbuts
cbuts
canada,ont
cbuts
