Car battery?
cbuts
got my battery tested, the interstate test from midas said battery replacement is highly recommended
battery results:
voltage 12.59V
measured 220 cca
rated 650 cca
temperature 22 C
starter test:
voltage 11.34V
time 2.47s
Charging system test:
no load 14.32v loaded 14.040v
ripple 70mV
-0.10v.
where would i buy a good battery that will be good for my system and start my car?
i drive a 2006 chev malibu lt v6 3.5l, its got a stock batt in it atm ( that apparently is bad )
im gonna be runnin 2 sa-12s with a rockford fosgate 1500
also a question about the subs, im not quite sure how i connect the wires together in the subbox, ill be wiring to 1 ohm.
thanks
I have had good luck with my yellow top as a starter. They are pretty cheap and can be found anywhere. Im sure there are better but it has worked for me. You will want to do the big 3 upgrade also for that amp
yeah, im going to do the big 3 when i can get some spare change, is there any good batterys on canadiantire.ca ??
and what kind of yellow top, i need to know what i should be looking for :p and the price.
thanks
---------- Post added at 09:41 PM ---------- Previous post was at 09:41 PM ----------
thanks
I have a Power Sonic 100 AH AGM Group 31 battery that I will consider selling you if interested. PM me if so. I can take pictures tomorrow. Never saw below 12.8v using a DD M3 pushing ~3300 Wrms wired at .5 ohms.
It is 2 months old.
cbuts
cbuts
canada,ont
cbuts
