Moble Enclosurs
Box Designer/Builder
You are missing two very important factors before determining proper battery replacement or even addition. What are the amp hours of the battery now, and also you have to figure for the charging systems alternator amperes. I believe for you vehicle its 115amps. Max replacement stock is 125 and the older models are 105. If you give me a bit I can figure for your proper batt replacement based off of amp hours and wattage hours but I would personally add to the charging system with a deep cell. Not replacing the stock batt unless the cca is too low for the upcoming winter.
