car audio troubleshooting
natez228
16
zfL
I'm having trouble getting my system to work. I put in new amp, sub and deck today, everything works fine except for the sub. The amp turns on, but theres no power to the sub. I checked everything, tried a new set of rca's...nothing. I'm getting no voltage at the amps speaker terminals.
I've narrowed it down to a problem with the Rca outputs on the HU or the amp having a problem.
Does anyone know what voltage i should be getting at the decks rca outputs and the amps speaker terminals?
I double checked the voltage coming out of the rca's and im only reading .025 volts @ the 2V setting, the next setting 200v reads nothing.
Tried another head unit, still nothing coming out of the amp.....
What voltage should be coming out of the rcas that are hooked up to the headunit?
correct me if I am wrong but.. it varies with your volume. what is the pre out voltage for your HU?
natez228
natez228
zfL
vandiar2
