Wiring amp to stock hu on 05 Grand Prix
IGNITION 1 PINK (+) See NOTE *1 IGNITION SWITCH HARNESS
NOTE *1 there are (2) PINK (+) wires that test as an Ignition wire, to test for the correct PINK IGNITION wire. Place the Key in the Ignition Switch but do not turn to the ON position. Try the remote starter, if the KEY in the IGNITION CHIME turns on, you are energizing the correct PINK Ignition wire.
That's for installing remote start and alarm, but it may help.
depending on the draw you can hook it up to your wiper fuse. It is big enough to carry the load and would shut off when you turn off the ign.
Or else pull the radio out and get it from there also.
depending on the draw you can hook it up to your wiper fuse. It is big enough to carry the load and would shut off when you turn off the ign.Or else pull the radio out and get it from there also.
I am almost positive that the radio's in these cars do not have a ign wire.
Is there any wires in the trunk that would work? I am assuming since you tapped into the rear speakers you are in the trunk doing your work. Power antenna wire if you have one? I am just wondering.
bjfish11
FisherCustoms.com
bjfish11
Garden Plain, KS
bw_audio
