Car Audio Facts.
Install is more important than equipment.agreed
A pleasing sound does not equate to SQ.
agreed
BOSE is a four letter word.
agreed
If you can't measure a difference between two componenets, you can't hear one either.
yep
Running your power wire with your signal wire will not cause noise.
not sure
Your power delivery is only as good as your ground path.
agreed
Alternator whine is a ground problem (usually the HU).
agreed
You can fuse your power wire according to the needs of the amp or the size of the wire.
agreed
Speakers do not need an amp capable of delivering the RMS rating of the speaker to sound good. That goes for subs, too.
yep
JL is not overpriced.
STRONGLY DISAGREE//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
SQL is a database architecture not an audio term.
agreed, your system is either one or the other.
Ported is not always louder or less accurate than sealed.
i suppose but I've always believed sealed to sound the tightest and most accurate
There is no "best" anything.
true
Anyone who makes a post asking "Whats' the best..." is a noob.
i guess
no- i think he is really that retarded... just look at him in the "snickering at jl" thread...
It was a trolling thread. Again, nobody is that stupid. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
He's done nothing the past couple days but try to stir up trouble via JL Audio reject-talk. He's probably just another member too chicken to act this way under their regular name.
But I dunno, you might be right and they've started placing computers in the special ed classes at his school.
while i was being sarcastic, i really do believe he was serious in the jl thread....
Unibody car here but 3 wires upgraded under the hood. It may not have a frame, but it still has a chassis. Bat to alt, bat to block, bat to chassis. Last I checked that's 3 and a frame has nothing to do with it.
I've never met anyone that upgraded their bat to block wire. It's totally unnecessary. And yes, the frame in a non unibody vehicle has everything to do with it. That is part of the "big 3". Not sure where you got your information but I have to disagree with you.
So in my case, with a unibody I upgraded the "big 2". batt to chassis and batt to alt. That is all.
60ndown
60ndown
ca
supa_c
