Sold car audio and xbox 360
f150john
KnuKonceptz 1/0 wiring kit with anl fuse holder and 200 fuse-50+shippin
knukonceptz 4 gauge wiring kit with 80 fuse-30+shippin
kicker sxrc comes with oringial box-35+shippin
kicker sx 400.2-$120+shippin
kicker sx 1250.1-$260+pp fees
2 12 l7 dual 4-each $125+shippin or $270+pp fees also have a box i can throw in.
xbox 360 pro-$340+pp fees
faceplate
cod4
charge kit
hd dvd player
2 hd movies
black wireless controller
need money offer lookin to get a quad.
1250.1
Number of Channels : 1
RMS Power (4 ohms) : N/A
RMS Power (2 ohms) : 625 watts x 1 chan.
RMS Power (1 ohm) : 1250 watts x 1 chan.
Bridged RMS Power : Not Bridgeable
Peak Power Output : 2500 watts approx.
Min. Impedance Unbridged: 1 ohm
Min. Impedance Bridged : Not Bridgeable
THD @ Rated RMS Power: 1.5%
Speaker Level Inputs : No
Amp Preamp Outputs: Yes - 1 Pair
Built-in Crossover: HPF(10 Hz - 60 Hz), LPF (30 Hz - 200 Hz)
High-Pass Crossover: N/A
Low-Pass Crossover : N/A
Signal-to-Noise Ratio: 98 dB
Channel Separation: N/A
Bass Boost -18 - +18 dB
Bass/Gain Remote N/A
Fan Cooled: Yes
Fuse Rating: 150A
Warranty : 1-year
400.2
Power (WATTS/CHANNEL), 2 Ohm Stereo 200 x 2 Power (WATTS/CHANNEL), 4 Ohm Bridged Mono 400 Length With EndKaps (IN., CM) 16, 40.64 Width With EndKaps (IN., CM) 10, 25.4 Height With EndKaps (IN., CM) 2-1/2, 6.35 32-Bit User-Programmable Digital Signal Processing:UltraMatch Gain Structure; single-band parametric KickEQ (variable frequency, boost/cut and Q); high-, low-, and band-pass crossovers (variable frequency, 6-36dB/octave slope)Frequency Response: 20Hz-20kHz; +0, -1dB Input Sensitivity:100mV-16V in five selectable ranges (1V, 2V, 4V, 8V, 16V)Signal-to-Noise Ratio: 100 dB, A-weighted, re: rated power, DSP Bypass OnPAST Output RCAsRemote Gain Control (Full Range)Fan Cooling
kicker sx 1250.1-$250+shippin
2 12 l7 dual 4-each $130+shippin or $260+shippin also have a box i can throw in.
xbox 360 pro-$330+shippin
faceplate
cod4
charge kit
hd dvd player
2 hd movies
f150john
f150john
nj
f150john
