Sold car audio and xbox 360
f150john
KnuKonceptz 1/0 wiring kit with anl fuse holder and 200 fuse-50+shippin
knukonceptz 4 gauge wiring kit with 80 fuse-30+shippin
kicker sxrc comes with oringial box-35+shippin
kicker sx 400.2-$120+shippin
kicker sx 1250.1-$260+pp fees
2 12 l7 dual 4-each $125+shippin or $270+pp fees also have a box i can throw in.
xbox 360 pro-$340+pp fees
faceplate
cod4
charge kit
hd dvd player
2 hd movies
black wireless controller
need money offer lookin to get a quad.
sx 1250.1
Features
* Built-In 32-Bit Digital Signal Processor (DSP) - UltraMatch Gain Structure; single-band parametric KickEQ (variable frequency, boost/cut and Q); high-, low-, or band-pass crossovers (variable frequency, 6-36dB/octave slope)
* Isolated dual power supplies
* Fan cooling
* Remote gain control (Full Range)
* Custom-tooled oversized power and speaker output terminals
* PreAmp Signal Transfer (PAST) output RCA lack
* Soft muting circuit controlled by the DSP
* Soft start turn-on circuit for deduced startup load
* Removable cast aluminum EndKaps
* In / Out strapping ports
* 1-ohm load optimized
Specifications
* Amplifier Type: Mono
* RMS Power: 625W x 1 @ 2 ohms
* RMS Power: 1250W x 1 @ 1 ohms
* Bass Boost: 0 - 18 dB
* Frequency Response: 20-200 Hz
* Signal to Noise Ratio: >100 dB
Dimensions with EndKaps (Inches)
Length: 22.5"
Width: 10"
Height: 2.5"
sx 400.2
Kicker SX400.2 2-Channel Amplifier with DSP
32-Bit User-Programmable Digital Signal Processing
RMS Power Rating:
100 watts x 2 channels @ 4 ohms
200 watts x 2 channels @ 2 ohms
400 watts x 1 channel @ 4 ohms Bridged
UltraMatch Gain Structure, single-band parametric KickEQ (Variable Gain, Boost, and Q), and crossovers ( Variable High and Low-Pass Filters )
SAMS (Stereo And Mono Simultaneously)
ISIS (Indicate Status & Input Settings) Interface
SORT Protection Circuitry (Shirt Circuit, Over-Voltage, Reverse Polarity, Thermal)
BLAST Port (Bass Level And Signal Transfer) Provides Remote Bass Level Control and control signal transfer between multiple SX amplifiers
Kompressor
Adjustable Phase Control: 0 - 180°
EndKaps: Cast aluminum, custom, removable covers to protect and hide all your wiring connections to the amplifier
Amp Strapping lets you put two mono amplifiers together into a single unit with double the power.
SickBay and On Board Diagnostics
Left and right channels can be adjusted together or separately.
Frequency Response: 20 Hz - 200 kHz
Remote Gain Control with 20' cord
Variable Input Sensitivity: 1V / 2V / 4V / 8V / 16V
Signal-to-Noise Ratio: >100 dB
MOSFET Power Supply
RCA Outputs: 1 Pair
Remote Gain Control
Fan Cooling
Dimensions (With End Caps): 19-1/4" L x 10" W x 2-1/2 H
Authorized Internet Dealer
2-year Manufacturer's warranty
f150john
f150john
nj
f150john
