caps when is one needed???
  • 3
there are 2 parts to power
1 current
2 voltage
cant have one without the other in a car system (amps x volts= power)
caps are to maintain voltage as a reserve(they store it and recharge very quickly due to low resistance) they help "dimming" lights but their main purpose is to relieve stress on the amplifier so it can pruduce what it wants...a better wave
they dont do much as far as current that is why they started developing the batcap. if you dont run anything "souped up" in your electrical system a cap will help but remember its not a fix for a weak alternator i always suggest rebuild your factory alt bump it up 10-20 amps (they can do it in the rebuild) and then add a cap.....1 farad to every thousand watts ..you do this you'll get the most out of your basic set up.
I did an adire koda 8 for now but I'm considering swapping it to a Dayton ho 10. More cone area for more midbass. But I might not need to. I might...
16
I've been very happy with my jy battery, but I likely won't buy another jy product. It irritates me they discontinued their hp40 battery...
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
525
I have confirmed through JL that these subs have just over 1inch xmech. As long as there is 1inch clearance in front of the front edge of the...
rsflores
just tryin to live,life
rsflores
houston,tx
audiolife
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
