audioholic
not a moderator
so you think the dual xxx 15s will exceed in SPL wise vs all the other subs mentioned with 1200W rms to each sub? How much do xxx 15s go for? and whats the recommended volume for each driver?
I do not know which sub would give the most SPL, I was commenting only on the distortion output when comparing to the others. I suspect which would be loudest would depend much more on your install than which of these subs you chose, as they are all very capable drivers. Chosing subs based on what people tell you 'gets the loudest' isn't a very sound way to go about picking your subwoofers. If you want the loudest setup you can, you should be learning how to maximize your install, not on the net asking people which sub gets the loudest.
My comment on the xxx's output was simply that two xxx 15's set up correctly will give you more bass than you are capable of listening to on any regular basis. A pair of any of these 'super subs' should be capable of pounding harder than you'll want to listen to for any length of time. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif But at some point imo whether or not one sub or another can get a db louder is not nearly as important as which one sounds better. How often will you listen at absolute 100% volume so that db or two difference even matters? But the SQ differences will always be there. Go with the choice that makes most sense for other reasons like sound characteristics you prefer, price, and availability (back orders and pre-orders are rampant). Arguing over which sub is 'loudest' usually only gets you arguments.
