rubix777
I was wondering how you guys wire your caps between your amp and battery. Do you wire it inseries, so that the electricity goes through your cap first or have it wired parallel. I figured if I wired it in series, the amp would drain all the power within the cap and it wouldn't be able to recharge immediately. I was thinking that the correct way to wire it is parallel that way the amp receives constant power from either of two sources, cap or battery. Anyways, am I right?
