Cap or alternator
A 60 amp charging system doesn't leave many spare amps for accessories like stereo systems. Id hate knowing I couldn't turn up my stereo if I was running the AC without worrying about voltage issues etc, for example.
a/c needed in maryland? //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
since CAPs do nothing and alternators are the core of the electrical system, an Alternator would be my choice.
Good upgraded battery is a must as well.
CAPs are a waste of money.
ok so i guess ill start with a new battery cause the one i have is pretty beat, if that still dosnt solve the problem then i can go with another alt. now would i be able to buy one that pumps out more then 60 amp from autozone or something or do i have to go with an OP alt from a custom dealer? money is deff an object here so looking for the best cheap fix (if cheap is an option, i know sometimes its not)
battery over a cap as a cap won't "help" unless everything else alt and battery wise is up to par. If you are going to replace your battery look into agm type batteries like kinetik
I would also like to know what would be better for a 2001 Caddy Deville, cap, alt or battery, ive heard from alot of places that my best bet would be a cap, i told them i beg to differ and that i would be better off getting a battery, any thoughts?
the alt in my car says 60 amps on it
I'm running 1600+ watts with a single battery
but i do get low voltage with AC on...
But amp voltage barely ever drops below 12v, even at idle
drdroopy
drdroopy
east lyme, ct
Rashaddd
