cap and battery FAQ insight
518wrx
I FOUND THIS WHILE SEARCHING THE NET AND THOUGHT IT MAY BE HELPFULL!
There are a few benefits to using a cap in a daily driver. The cap installed near the amp is able to discharge faster then the battery upfront. This allows for less strain on the alt. due to the fact that there is less resistance compared to pulling the same amount of current all the way from the battery (resulting in a lower voltage at the amplifier). The cap will recharge quicker then any of us can measure so don't worry about it only helping the first hit. One major problem is most people that need a cap are usually maxing out their amplifiers consistently, as opposed to someone that uses them to "critically listen" to music. When the gains are set properly the amp is very dynamic, some beats on the drum are not as loud as others, and you can tell the difference. In that scenario the cap helps on the big swings. When pounding down the street with a bass CD in, the amp is not "swinging" at all, it is constantly using everything it has, and this is using more current then the alt. and battery want to give up. This is why your lights dim on every bass note. The chance of a 1 farad cap helping this are very slim to none. The reason is the alt. can't keep up and charge the battery and the cap. A bigger alt. would be the way to go. Or for a quick fix add a second battery in the trunk. This will help with the lights dimming and put more power in the back (because it stores more energy then a cap). You still have the problem that the alt. cannot put out enough juice to properly charge both batteries (that means charge them and maintain them at 14.4v) The trade off here is the same reason that the caps don't work for SPL-----
The extra battery and the cap both become a load to the alternator.(just like your amp is a load on the battery and the alt.) So the alternator basically "bogs" down and the operating voltage will be lower with more "loaded" on it. Your spl numbers will go down as the voltage goes down (NOT AS NOTICEABLE WITH A TIGHTLY REGULATED POWER SUPPLY). This is why most guys in street class gain almost a dB when they take out their caps. They have raised the operating voltage of their amps.(remember this is only for a short burp).Much in the way that ss and extreme guys "up" their voltage to get more power out of their amps.(remember that an amplifier steps voltage up inside so 1 volt difference can be a lot of power------ 12v in x3=36v+ and 36v- =72v across speaker leads now square that and divide by 4 ohm load= 1296 watts...... now with a 13v supply 13 x3=39+,39-=78v x 78v=6084/4=1521
1521-1296= 225 watts difference by maintaining 1 volt higher)(keep in mind your 4 ohm speaker has an impedance curve that is much higher then 4 ohms at most frequencies so real power is much lower)
The way caps have helped in most cars is that the alternator now has another load. This load now lowers the average operating voltage of the cars electrical system example:
Before system- car running nothing else on 14.4v
Add system- system down 14.2v- when bass CD is pumping- 12.4
Now your electrical system is varying between 12.4 and 14.4v---- a 2 volt swing
Now add in a cap or two and the system now charges at 13.4v
Now your system will still dip close to the same 12.4v, but the high is now only 13.4= a 1 volt swing
Now your headlights dim half as much because there is only half the swing in voltage.
Now if you put a second battery in the back (more storage) the operating voltage will drop even more, lets say 13 volts (now you are barely charging the batteries without upgrading your alternator) By adding the battery in the back, you no longer are loosing voltage along the wire from the front battery. Also you have a lot of storage (2 batteries) so when you bass it up the power is coming mostly from the batteries and the alternators job is just to charge those batteries. So now when the amp hits a big rolling bass note the batteries will only drop to 12.6v
Now your swing is from 12.6-13v and .4 voltage drop on a headlight or dash light is next to nothing especially when compared to a 2v swing.
One other suggestion is to ALWAYS upgrade your ground wire at the battery. This is the least expensive way to make a huge difference in light dimming. There are a lot of cars that use a 8 or 6 gauge ground to the body (remember when you grounded your amp?) This cannot support the current return of the headlights and a 1000watt amp. Remember you may have a dedicated 4 gauge lead to the amp, but when that current returns to the battery it shares that ground with all the other components in the car that are grounded to the body.
All of the numbers in this post were submitted to show a point and do not actually reflect a single test environment. They only are used to help visualize what is happening to your cars electrical system when you go crank your bass up all the way and cruise down the street. Hope this has helped.........
Gary Bell
and to the last part, dont upgrade just your ground to the body, upgrade your whole big 3. and do that before you do anything else. it is the cheapest and most effective upgrade you can do for your electrical system. if you dont upgrade your big 3, but get a bigger alt (we will say 250 amps)
how is your alt gonna push even 200 amps through 8 guage wire. its not possible.
This is good info for the noobs. Just someone took the time to type all of that. However, the scenario he saw in the vehicle he tested in above, someone else may have a completely different outcome in their car. People need to remember that every car and every system are different. Everyone should start with the BIG 3 and probably a good front battery, then test your system and adapt from there. Most likely, if you have over 1000W RMS, you will see an improvement with a rear battery. If you go over 2000W RMS in most vehicles, an HO alt becomes necessary. But those are just loose guidelines. There are so many variables that come into play that you can't give cookie cutter solutions to such dynamic installs.
not always, i ran 2 IA 20.1's off a kinetik 1800, kineti 2400, big 3, and a stock 110 amp alt in my 06 silverado with a .8 voltage drop. so sometimes its not needed
Fuck caps //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
If you pay 100, 200 or whatever for a capacitor you could be spending that on batteries or wire or building up to buying an h/o alt, which will help a lot. I added the big 3 and an extra battery and have almost no dimming at all. Very slight dimming when it's maxed out.
You had some badass batteries there too. Like I said, most vehicles. Larger V8 cars and trucks might get the job done with the stock alt. But, here is the kicker, for how long? My stock 70A alt held up for about 5 months. At first it ran fine and kept up no problem. Then one day it just crapped out. The car only had 30k miles on it, so it wasn't old by any means. That is just the chance you take running a stock alt.
thats a good read...thanks!
since this is a cap thread...can anyone recommend me a way to wire 1 cap for 2 amps
one is a PG rsd500.4 (mids) rsd1200.1(subs)...since the sub amp is more efficient should i
wire the cap to mids amp?
Just wire it to your distribution blocks. Both amps will benefit from it.
518wrx
518wrx
Albany,NY
midnightg35x
