Can this set up work?
brafferty
I have my H.U. and Speakers set up, so ignore those factors. I am wanting to purchase 2 SWR-12D4 (4ohm x 4ohm), and wanted to by a Soundstream Ta1.2000. I was wanting to run this amp at 2 ohms (for a total of 1300 watts, 650 per sub) but am not sure if this is duable with these subs? thanks in advanced
Thanks for the quick reply, as much as i was set on that amp, so what if i went with the SWR-12D2? would that set my final at either 2 or 8? Im still learning
Wire like this
Ill have to look later, my school wifi blocked that site apparently //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif, and while im here, think running this amp at 1300 watts and another alpine at 85 rms x 4 is too much power for a modern battery? Ive been told no beacuase i have a newer ('03) outback but am not so sure
1. Foo your at school get off your phone! Lol2. Its an image but same thing as that link you posted
Im in web design class //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif and thats for clarifying that, although i edited my post around when you posted yours.
The only way to find out is by trying it out. Get yourself a digital multi-meter and see what your voltage drop is. Make sure your gain is set properly and you should be straight. You might need to do big 3 but i think you should be fine. But like i said the only way to find out is by doing so. Dont cheap out on power wire, thats what will make or break it. Bite the bullet and buy ofc wire. Knulonceptz sells a goof kit for like $65
Ill have to check it out, right now im running a single oineer off of a 900 watt amp, and the speakers of the HU so i dont think thats nearly enough power to compare the 2 set ups
brafferty
brafferty
idaho
brafferty
vegang
vegang
