can speaker wire be used as power wire?
so im guessing the answer is yes for wire harness extension? how bout speaker wires from battery to amp? this sounds like a no-no
look dude.. metal is metal.. it has load ratings.. you can do w.e the hell you want with it but if you exceed the load warnings you will blow fuses if you don't have fuses you will make a fire..
load warning = gauges?
no.. they only carry watts.. no volts allowed
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
look.. wire has volt and amp loads it can carry.. it has specs.. with 12 ga wire you can't run an amp unless its pulling like 20a or less.. or you will melt it and or cause a fire..
yea thats what i meant
word lol
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
790
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
Ppl love their Cruze Often it’s increasing the turbo size, changing the suspension from stock being fe1-3 to fe5, sway bar and links then brakes...
thaster
thaster
pennsylvania
KyleBechtold
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
