Can someone help me with my problem?
Is there a sub level volume on the deck? I know mine has one...try and check that..
Also try and see if they rate their amps at 17v....I know MA used to do that before...
Yeah, it has a sub level volume. But I thought I was to leave those settings flat ???
The subwoofer setting is at 80hz and 0 volume level. But when I put it up to the max, which is to 6, the AC voltage does go up a bit. Im in the low 30's, but I need to get to 66 volts. Its weird why the settings on the amp arent making the voltage go way up //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
When I put the "loudness" to ON just for fun, the voltage increases a little. But the test should be done with it OFF, correct?
95Prober
95Prober
Canada
95Prober
