Can someone help me determine box size/plans
or take your spare tire out, or build it in the trunk....or take off ur back seat and put it in that way......or maybe it'd fit with ur backseats down....lots of possibilites here
just depends on how much work u wanna do to get it there.
I took all the trim and spare tire out today to try and fit a 26x27.5x16 inch box in there today....didnt work
I dont know if that will fit.
If I go sealed will it be a lot quieter? Think a 15 inch SSD sealed with 800 watts can beat a 12 inch CVR ported with 400 watts
idk, idk what an ssd is. and cvrs in a good ported box can get loud. so i say ya, your screwed. The best thing is to see if that box i made up will fit. its shorter then what you had, and your trunk looks like it will take 23" on the bottom. If not, shrink the hight and add to the lenght. You had plans for a 27" so if its shorter, it should go in.
Maybe mock one up out of cardboard and tape and see if it slides in?
idk, idk what an ssd is. and cvrs in a good ported box can get loud. so i say ya, your screwed. The best thing is to see if that box i made up will fit. its shorter then what you had, and your trunk looks like it will take 23" on the bottom. If not, shrink the hight and add to the lenght. You had plans for a 27" so if its shorter, it should go in. Maybe mock one up out of cardboard and tape and see if it slides in?
Its an fi SSD
Good sub. It cost $214 bucks new
so make a square of cardboard 16 high x 18 long will fit in the trunk without catchinh. and then make sure you have 28" free side to side.
I have already tested the 16 high x 18 long I just have to check 28 side to side
I just went and re measured and I was way under estimating the length of my trunk
I can go at LEAST 30 inches probably even up to 32 inches long
Think I can make ag ood ported box with that space?
Hows this look
I changed the port width to 2.9 so it would be tuned to 33.4 hz
[/img]
darkhunter139
darkhunter139
PA
darkhunter139
