can someone design me a box for free?
would port placement make a big difference? i would like to have the ports on the top of the box but them needing to be 20-21" long that would put them within 1-1 3/4" from the bottom of the box which i think is to close?
so should i place the ports on the sides of the box porting into the cab corners or straight up towards the roof
That 21" is not counting the flares, that would add at least an inch. That's not enough room to face them up.
this has caused a problem, because only other place i could place the aero ports are on the sides of the box, porting them into the cab corners which my box is going to be so big that it will cover the whole cab corner opening, so it would be porting into a pretty much sealed area,
question is aero ports into the cab corners or slot port pointing up
not really...you may feel the air coming out of the port onto your feet though. I'm going to crunch the numbers for ya for port length...something about dude's measurements don't sit right, probably cause I simply don't trust winISD.
.35 is compact .5 is optimal but for 6 re 8's it is pushing the limits for airspace in my truck so i can only get 3.4 cubic feet gross box before any displacements
For 6 RE8's at .5ft^3 each, each 3" port needs to be 20" long. Subtract the 5" that PSP inc requires gives you a 15" long tube. Glue on the flares and you've got your box at 3ft^3 tuned at 30hz...
the way i have been trying to tune the box is find out the total cft of it then subtract the displacement of the drivers and then type that in on a port length calculator as cft volume of the box and then figure up the displacement of the port and subtract that from the total gross cft and the driver displacement and see if it leaves me enough airspace the drivers need is that the correct way?
bvr_j_0969
bvr_j_0969
kentucky
j3bus2k3
