can someone design me a box for free?
bvr_j_0969
like the title says could someone design me a ported box for 6 re 8's tuned to 30 hz?
its a truck wedge box i have all the deminsions i just cant find the port lengths
52" long, 10" bottom depth, 5" top depth, 21" tall i think the gross volume is 3.4 cft.
using 3 3" aero ports with flared ends. im not even sure i can get enough port volume with these ports for 6 ported?
subs specs .35 cft per sub ported subs displacement is .07 per sub.
i would like to use just 2 ports but not sure if i could get anywhere near the port volume i would need?
It's easy you just subtract the flares and then calculate the volume of a cylinder.
but the flares take up displacement too? im trying to get this as acurate as possible, also i read in another thread searching, someone said the more ports the more spl?
The inner flare doesn't count I think?
The outer flares would take up so little space I probably wouldn't even count them.
As far as port area I would just worry about having enough so that you eliminate port noise.
OK for a 30 Hz tune you would need 3 3" ports 25" long each. The inner volume would take up .307 square feet. Although someone might want to double check my math.
Aeros don't make any difference compared to regular tubes, you just have to add an inch or so.
I actually calculated it wrong, it should actually be about 28" for a NET volume of 2.1 cu ft.
edit. I read your post wrong, I thought you said you have .35 for every driver.
For your box they should be about 20-21", my bad.
bvr_j_0969
bvr_j_0969
kentucky
j3bus2k3
