Can it run at 1 ohm?
TheOol
The plan is to get the new RF T10001bd for the 4 ohm DVC Type R's. But on a recent trip to the local shop a salesman told me even though RF claims its 1 ohm stable, it won't last long before shutting down at 1 ohm. Is this guy full of it? Anyone run theirs at 1?
the local shop here where i live said they was stable also. but they put a T30001 on 4 12's at 1 ohm and have burned 3 of them up. now the guy is running 2 T30001 on 6 T2's 12's. they only lasted a few hours at 1 ohm.
Running at 1ohm is always risky, I personally dont like to run at that low of a load, unless you have a very realiable amp. If it states it will, do it, unless you take into consideration what you have heard.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Is it somehow possible to wire the DVC 4ohm subs to 2 ohms then? And nobody has any experience successfully running the new rockfords at 1 ohm?
Well if your that worried about it man, just get you a crossfire 1000 watt or a Directed 1100 watt, maybe even one of the boodles of 1200 watt amps that tons of companies make---orion, ed, kicker, viper (discontinued)----plus, its rockford, step up a notch into som real companies //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif, not dissin on u tho bro, just sayin since u havent bought amp yet...
plus, its rockford, step up a notch into som real companies //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif...
RF is not a "real" company anymore? I believe they are still, very real.
the only other ohm load you could get would be 4, but i dont think that amp would put out near enough power for 2 type r's but i dont know the specs either
TheOol
TheOol
Phoenix, AZ
AllStar1500bd
