Can I run my subs off of different amps?
09VIC
20
Atlanta
I currently have an ssl 5000d hooked up to two dvc4 alpine type R's at 1 ohm. I have been made aware that amp can't cleanly supply my subs with enough power so I plan to either purchase a cab 1600 or an audiopipe 1800 to replace it. In the meantime until I get the money I have a belva bb2000 amp hooked up but not powering anything so I was wondering if I could run my subs off of the two different amps wired to 2 ohms. My subs share a box with their own chambers but a common port. My ssl will make 800 at 2 ohm and I haven't seen a Dyno for the bb2000 but the bb3000 did 900 at 2 ohms so the bb2000 should be good for 600 rms (my goal for each).
can i smoke crack while getting head? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
you wont see any output increase..
can i smoke crack while getting head? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifyou wont see any output increase..
I want them to get cleaner power which I assume they would at 2 ohms. If they are slightly out of phase with each other can it damage my subs?
No it won't damage anything. The power will be as clean as you set it. You control that with the volume and gain knob.
Your much better off running that CAB amp, if you get one, compared to others. If you got the big 3 done and/or aftermarket HO alt, you should hear a dramatic increase over those mentioned amps as far as output, once gain is properly set.
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
09VIC
09VIC
Atlanta
Papermaker85
    May 16, 2024
    May 16, 2024
