can i run a second rca wire from my HU?
2 to the headunit
these you connect your RCA's to and run to amps
went outa my way a tiny bit lol but trying to help ya out. PS if you want these ones off me they are brand new just opened them for the pix like 5min ago $6 plus shipping
you will plug one why into one jack and the other into the other SW jack on the back of your radio. Then plug one side of your RCA into the left Y and the other into the right Y then you will do the same with the other RCA cable then you can just run them back to your amps like your normally would.
Im trying to explain this as simple as possible for you
thanks for clearing that up. i was just curios as to know where the single ends would go.
and you would need to y off your Remote wire from your first amp to your second. I wouldnt run the rcas like tho. I would spend the couple dollars and buy 2 Ys and another rca and run it the RIGHT way and not the lazy way
How is it wrong to dasiy chain amplifiers ?
2 to the headunit
very helpful. Thank you. Thats probably what im going to do. actually thats exactly what i plan to do
2 to the headunit
so i need 2 y adapters right? one is a 1male/2female and the other is a 1female/2 male? is that right?
marquisbrah
marquisbrah
fresno cali
Kangaroux
