can i run a second rca wire from my HU?
marquisbrah
my HU has 3 pluggins : R (with a red and a white) a F (with red/white) and SW (with Red and White.)
my amp is currently wired to the (SW). im putting in a second amp (identical, but for another identical sub), but i dont know where to run the RCA from the HU for the second amp.
and you would need to y off your Remote wire from your first amp to your second. I wouldnt run the rcas like tho. I would spend the couple dollars and buy 2 Ys and another rca and run it the RIGHT way and not the lazy way
where do the y's go? what kind?
you will plug one why into one jack and the other into the other SW jack on the back of your radio. Then plug one side of your RCA into the left Y and the other into the right Y then you will do the same with the other RCA cable then you can just run them back to your amps like your normally would.
Im trying to explain this as simple as possible for you
the males go into the RCA jack on deck (SW) and rca wires run from females to the amps
so what you are saying is that the single tip is the male, and each of the 2 y-adapters go into the red and the white rca on the SW part of the HU?
marquisbrah
marquisbrah
fresno cali
Kangaroux
