Can I hook up this together?
Octavio
If yes .... please tell me how ............ I wanna get this and hook up ....
1. 200x2 Kickers
2. CVR8 (2 sub)
any help would be apreciated it.
Sub
http://sonicelectronix.com/item_3413.html
Amp
http://sonicelectronix.com/item_6591.html
item_3413.html
what kind od sub would go here?
200W RMS (continuous) x 2 @ 4 ohms
dual vioce coil 2 or dual voice coil 4? I don't get it can someone please explain
If a sub is dual 2 ohms those that mean is a 4 ohms sub? right
But you have two dual 2 ohm subs. In that case, you can wire to 8 ohms, .5 ohms, or 2 ohms.
Series wiring:
R1 + R2 + R3 + R4 = Rtotal; where Rn= each coil.
Parallel wiring 1/R1 + 1/R2 + 1/R3 + 1/R4 = 1/Rtotal
You can use each method together to get different values. For instance, if you wire two dual 4 ohm subs in series and parallel, you will get 4 ohms.
Sub 1 parallel coils:
1/4 + 1/4 = 1/2 = 1/Rtotal... Rtotal = 2ohms
Sub 2 parallel coils:
Now them in series with each other:
2 + 2 = 4ohms final load.
It's simple math. Remember it and never look like an idiot again.
jmoreno150>
(2) 12" alphasonik psw912 (2200rms each)
(4) 6.5 alphasonik mids
(2) alphasonik 6x9's
(4) lanzar titanium 100 rms tweeters
(2) 1" alphasonik tweeters
(1) ma audio hk 4400rms amp.
(2) alphasonik pmz 4ch amps.
(1) kinetik hc1800 (1900 amps)
all wires are stinger
tsumnami cap.
clarion vrx765vd indash.
clarion is good, stinger wires are good, but why all the alphasonik stuff? I had 2 alphasonik 10's as my first system, but I didn't realize how crappy they were until I heard other systems with better equipment....and as for their amps...the 300 watt amp that came with them blew the first time I turned it on.
jmoreno150>
tsumnami cap.
Octavio
Octavio
Nic
Octavio
NorthFramingham
    Jun 30, 2026
