can a 8" woofer be used as a mid-bass speaker ?
ya thats what i was thinking but figured i would ask.
as im looking around for 2 8" mid-bass speakers.
im thinking of putting them in my doors.
was hoping they would work as i like sq stuff.
thanks guys.
Mid bass is designed to play mid bass. 60-250hz ONLY. Some will get up to 300hz but that's it. Midrange is 250-3500hz plus or minus. Some can play under 100hz but it's not the same.
o ok. so a 6.5 would be mid range not mid-bass right ?
see i have a set of aq 6.5 comps coming and was thinking adding mid-bass speakers to the doors as well.
maybe i should ask, should i go with 2 8" mid-bass in my doors if my plan is to add 3 sets of aq/sq 6.5 comps to my doors ? ( will be installing 1 set in a few days. )
or will 3 sets of aq/sq 6.5's be a enough ?
o ok. so a 6.5 would be mid range not mid-bass right ?see i have a set of aq 6.5 comps coming and was thinking adding mid-bass speakers to the doors as well.
6.5 can be mid bass. Like the DD and I think CDT has one. For what you are planning I don't think a single mid bass per side would keep up enough to be noticed.
There is a difference in mid bass or midrange like already said.
If you want to run a mid bass woofer you are going to also need a midrange and tweeter making a 3 way front stage.
The AQ comps will play from 60-20k just fine. No need for a dedicated mid bass.
I think its pointless to run 3 sets of their components. You would be better off buying raw drivers and tweeters from parts express and running active.
that is an Ideal crossover and designed for use in an home type loudspeaker. A simple Linkwitz-riley 2-way is easy enough/ The tweeter wire lead...
36
Those subs are 400w RMS each, and that dual enclosure is 800w RMS with a 2ohm load. That's a 4ch amp that does 55w x 4 @ 4ohm, & 75w x 4 @ 2ohm...
819
  • Locked
Looks familiar: https://www.caraudio.com/threads/who-needs-new-equipment.613325/ Wouldn't that be a real kick in the ass. I shared that so...
And dont skimp on the Sql...that doesnt mean it dont get loud,that just means it sounds great while getting loud lol
Well yes, I've searched cruthfield many times, I just wanted input from actual people to go off of instead of numbers and prices. I've got it...
big scott
blazin low, and loud
big scott
edgewood, md
big scott
    May 12, 2024
Brendon Jenness
    May 11, 2024
