Can 8’s get loud?
Can 2 8’s get loud?
  • yes
  • no
Results are only viewable after voting.
If someone asks a yes or no question, and you don't answer with yes or no, how "it answer the question"?
Maybe that's just the difference between me and you. You do know that it's ok to be different right? You ask me a question, imma answer however the f*ck I want. If you don't like it then that's your problem.
That's not how effective communication works, but it explains why you spend so much time on the internet.
another problem with 8's is port area. some of these 8 need like18-20 in^2 per cube and your port can easily be 40 inches long.
That takes up a ton of box space. Like the sa-8's back years ago; even though programs said I wouldn't get noise, customer were saying they were getting a little at 16 in^2 per cube with square ports. That's wild to me. Only time that happens with larger woofer is when they are like 3000w+ plus woofers.
John858
CarAudio.com Recruit
John858
San Diego
resko1
