camp bandpass
etznova
ok here we go decided to try something different for my bonneville last box ported with 75 sq in of port 5 cubes diddnt do a whole lot of testing with but my top number with it was 145.6
now i try a bandpass on to the pics
here is tha base and a couple sides
here you can see the sub baffle and the front chamber and its port
here is the font the completed box veiw from the font baffle
and here is the main port lookin in
ok the run down
1 dd 9515 dual 4 ohm
2 memphis st1000ds strapped together
fisrt run 140.1 not happy at all when i saw that then i remember that i hadnt check to see if my amps were still matched well they were way off
now here is the other thing that is weird my car has always liked around 46 to 50hz so thats what iwas using
2nd test run was better 143.4
so now i decide to do a couple sweeps
turns out with this bandpass my peak was quite higher
3rd run and final for the night
148.6 db in a 97 pontiac bonneville
front fireing sealed off from the trunk
ive still got som tweaking to do seal up the trunk alittle better take some more time at matching my amps output and figure out the fequency deal
so what do you think
thats not a bandpass at all
it looks more like a folded horn
if u was going for a 6th bandpass.(cuz the front of the sub was ported as well as behind the sub)
u should have made the ported area in front of the sub bigger
but all in all good score...i feel u can do higher but for what u did thats good
80
bandpass guru
well i didnt design the box i cant tak credit for it i got the design from toxic bass you say your the bandpass guru huh maybe i will pm you some ? and you might be able to help me out a bit is that cool
he is a great guy. in fact a have i 6th order series tuned bandpass design from him to. just havent got around to building it.
but yeah ive never met anyone more knowedgable then him about box designs. to bad thier forum got shut down.there was alot of good information that went down witht that forum rip
ok here is looking back at the box behind the rear seat
here is the trunk side
here is the passenger side
and here is the driverside the side the main port is on
and just for kicks the inside
etznova
etznova
Cherry Valley, il.
hofulstrof
