C.L.E.A.N. setup
More companies? They've been on pretty much every Korean amps gain remotes for a few years.
Yeah on the gain remotes. Gain remotes are for fags. I've never ran a gain remote.
I like the idea rockford did by putting the DD on the amp itself. Too bad it is rockford.
it's not a clip indicator for just the amp's output. it pretty much a DD1 built into the amp. I'm sure it's SMD getting his paper that's why he has a patent on his DD1, he is partnered with RF. Kudos for SMD getting that paper.
what do you mean by getting his paper?
if that CLEAN uses the same circuitry as a DD1 or it relates to it, RF has the pay SMD to use it b/c the technology has a patent. if other companies try to follow this, they will have to pay SMD for the technology. it's like a sign or logo that is trade marked, if you use that logo you need permission from the owner and that permission usually means $$$.
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
705
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
984
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
LosIsATool
LosIsATool
Pensacola, Florida
serjr711.
maylar
    Jun 2, 2024
    Jun 1, 2024
