Buzzing issue coming from oem headunit?
Devzx
CarAudio.com Newbie
Hello, This is my first post and I know a lot of people post about noise issues but reading through them I cannot seem to find the exact source. Car is an 2018 Chevy Cruze LT without a factory amp so I’ve used a t harness in the back of the radio with 8 pairs of wires running into the trunk(speaker inputs/outputs. I connected the wires into my lc7i and rca outputs into my 4 channel and mono. Mono sub amp does not have any noise as the Low pass gets rid of it.
the 4 channel is making a static noise at all times with the car on or off before I start playing music, when the car is on and I hit play on Bluetooth/usb/aux it makes abuzzing noise. It sometimes varies when it starts and stops buzzing but mostly constant. Doesn’t change with rpm, tried moving amp grounds ausing a ground loop isolator, and even used another amp with no success. Battery is in trunk and grounded directly to negative.
Now when I plug my phone directly to the amp I don’t hear the buzzing, I tried connecting speaker wires to high level inputs and same buzzing.
So seems as if it is coming from either the wires going back to the t harness? Could it just be that the radio puts out a lot of noise on the speaker outputs? Could it be some sort of interference that is causing this? What should be my next step?
Why are you using a T-harness instead of just running the speaker level outputs from your HU to the LC7i, Pre-amps from LC7i to Amp, then speaker level from amp back to your speakers?
My gut is saying something is wrong with those T-harnesses or your HU doesn't like the split with the T-harness causing some sort of load or feedback issue.
It sounds like your your getting some type of ground loop interference. Unibody vehicles are notorious for bad grounds . I always pull an extra ground lead along with the positive lead direct from the battery . Then I upgrade power leads to alternator and beef up grounding under the hood by securing larger battery grounds to body and engine block block.
Wouldn't a ground loop be RPM dependant though?
Maybe ground the stereo ? I had this problem once just used a piece of speaker wire from a screw on my deck wrapped around the RCA jack or something
Devzx
CarAudio.com Newbie
Devzx
New york
cbuts
vegang
vegang
