Building a box today - advice
toledokid
I'm building a bigger box for my 2 Diamond Audio D6 12" speakers, they're in a prefab box tuned to 33hz right now, and they're just not slamming as well as I'd like.
I'm running a 06' zX1000.1 to them.
Could I get some possible box dimensions? Will measure my trunk if needed to get max dimensions, but it's a Pontiac Grand Prix, not TOO much space to work with //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif I would prefer a sealed box that can hit low. Watched some sick youtube videos of IA Lethal Injections and got super jealous that with my current setup I can't hit with that much power. (I know I'll probably not be able to either way anyways..)
also, I'm running 1/0AWG wire all the way back, but I still haven't done the Big 3 yet, would I notice a sound difference due to the lower amount of voltage drops?
Yes, less voltage to your amp = less power output = audible decrease
Yeah, just didn't/don't know how significant it would equal out to be.
Any idea on how many cubes I'd want to make a sealed box for hitting 26hz~ ??
Just sick of having the higher 40-70hz bass, while anything below that falls flat on it's face in terms of power.
Ok, the current prefab box measures in at 16 length x 36 width x 13 height.
I could accommodate up to 30-32 length, and probably 14 height, the width makes the box actually get jammed in, so I can't go any wider.
The port is 3 inch wide, 12 inch tall, and 12 inch deep (slot ported in between the subwoofers)
lol, I just did some real quick calculations, and plugged the numbers into WinISD...I got the tuning of that box to be 62hz //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Oh lordy. Where do I go from here now //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
You just build a new box man, if you build a decent sized ported box, tuned to around 32hz I'm pretty sure you'd be happy with the outcome.
toledokid
toledokid
Toledo, Ohio
baker08
